shift gear noise
BoatLessCaptain
Hi,<br />When I shift gear slowly my 2000 2 stroke yamaha 150 makes grinding noise. Is it normal?<br />Thanks for the help.
rodbolt
Re: shift gear noise
yes its entirly normal. your not shifting correctly. by shifting slowly your damaging the shift clucth and gear assy. that damage is non warrenty due to the customer neglect and abuse part. shift rapidly and firmly. you should hear one solid thunk as the shift engages. so for a noise due to inccorect procedure its normal. kinda like a bearing squealing cause its dry.
