Shift interrupt clarification
midcarolina
I have a Merc 5.0 with a alpha one gen 2 with the new style button shift interrupt switch........I have searched but could not verify....
Should you be able to physically rotate or ratchet the V plate that activates the button switch if you removed the lower shift cable from the shift plate? I understand in normal operation it should only work when prop is under load just trying to do a little troubleshooting without hauling the boat 30 miles........
Thanks
Re: Shift interrupt clarification
Ayuh,.... What's the problem yer tryin' to diagnose,..??
midcarolina
Interrupter is not working......just figured I would check the movement first, as the boat sat several years before I purchased from PO
yesterday I checked the proper adjustment of the lower shift cable... it was spot on, while I had the cable off I tried to rotate the V plate but it would not move, now I didnt put arm wrestling type pressure on it but thought it shouldnt be that hard...
Ayuh,.... As grub said, it oughta move easily against the spring pressure,...
midcarolina
Thanks guy's... now that I know for sure it can be tested like that, I can dig into it and see why it is frozen.
