Shift Interrupt Switch
1994almeida
Hi
On my 1997 MCM V6 4,3 LX GEN + when I shift into forward or reverse gear, the engine fails, because the Shift Interrupt Switch doesn?t return to his neutral and normal position. The Switch maintains pressed. I lubricate the zone, but the problem maintains.
What could be the problem?
If I remove the Shift Interrupt Switch only during one week, until the end of the season, I will damage the engine?
Thank you, Almeida
Re: Shift Interrupt Switch
Nope,...... You won't hurt the Engine,......
But,......
There's a good chance you could Destroy the Drive.......
Your Lower Shift Cable is Junk,........ Replace it with a Lower Shift Cable Kit..........
MikDee
Banned
Annoying little suckers when they act up!, but it's gotta be there. Maybe your lower shift cable needs replacing? (binding?) sometimes this is the issue.
