Shift Interrupt Switch
vstol
Hello All,<br /><br />I have a 1982 larson with a mercruiser 140. I am trying to find a Shift Interupt Switch part # 39670A28 as per the stemtostern website, they list it as NLA. Any help in locating a parts store that has this or someone that has one laying around would be greatly appreciated.
ziggy
Re: Shift Interrupt Switch
ok, so out of curiousity, what would a person do if the switch is NLA and there is no replacement of it. seems like ya have to have a shift inurupt switch on a merc. is there a aftermarket switch ya use? or does a $20 switch leave yer boat junk.
Originally posted by ziggystardust:<br /> ok, so out of curiousity, what would a person do if the switch is NLA and there is no replacement of it. seems like ya have to have a shift inurupt switch on a merc. is there a aftermarket switch ya use? or does a $20 switch leave yer boat junk.
I've Never seen 1 Go Bad,.........<br />Unless somebody was Trying to fix a Bad Lower Shift Cable by Bending the Switch Arm,... Instead of Changing the Cable,.......<br />Which is what gets Done eventually,....Anyway.........<br /><br />I'm curious as to Why vstol Needs 1,..???....<br /><br />You could always Update it to the Push-Button Switch................
vstol
The switch is for a friend of mine, the arm on his is bent and the button the arm presses when going into gear is intermentently(?) working. I will give the salvage yard you recommended a try don't laugh.<br /><br />Thanks for the help
