Let me introduce myself. Just got a 1988 Sea Ray Sorrento and boating on Lake Erie.
I am having trouble with the shift.
It was fine out of water and shifts hard around neutral.
I have seen the other posts regarding this situation.
Based on these posts it is either the shift interupt swithc or a bad cable. I don't think it is the cable since the shift is good when there is no load.
The question is those of you that had this problem did you find it an easy enough fix to do the repairs on your own. Have not had a chance to test the switch. Saw there were some that just bent the arm of the activator.
I relize this is a rehash of some posts but bumping it up may be of some help to me and others.
Thanks in advance for any comments.
