tu1aher1
- Jun 3, 2015
- 41
Hello All,
I have a 1985 Mercruiser 140 3.0 stearndrive in a 1984 Hammond pleasure boat runabout.
I took the boat out this last weekend for the over night fishing trip I with a couple of my buddies. Every thing went fine the whole night. We fished in several different spots stopping then going to other places. A while after the sun came up the boat started having the same old problem it had in the past. We were putting along about 25mph then all the sudden the engine would die. I put it in neutral with a little throttle and the boat would start up again just fine but as soon as I came back to idle and put it in gear, give it gas it would die. I noticed there is a slight hesitation right when I push the throttle forward then under normal operation the engine would get past the hesitation and rev up. I'm assuming this is the Shift Interrupter at work? The hesitation I mean? But now when this problem started to happen on the lake, when I pushed forward on the throttle, going in gear, the engine would encounter the hesitation but not make it over or "catch up" and just die and it got progressively worse. At first when it died going at cruse speed I could put it in idle and start it up again, put it in gear and get it passed the hesitation and then it would take off like doing a wheelie because of the throttle being so forward but eventually it would die again at cruse. Eventually stuck in the middle of the lake I would start the engine again in idle, which would start up fine, and push the throttle forward in gear with a load on the propeller it would die. It would run great when in neutral and I could rev it up as high as I wanted it to go.
I am completely baffled. the two problems:
1. Why did it eventually start dying at cruise speed?
2. Why is it dying at rest when I put a load on the propeller?
Are the problems connected? It seems like they are. Is this a bad Shift Interrupter Switch?
I verified the carb is getting gas. I tried to make some adjustments to the idle you name it, nothing. It is either electrical or carb as much as I can tell. I thought maybe the coil is getting too hot but I come to find out this is normal. I even took it out and cooled in down in a lake water being careful only to put the bottom in the water. I had it nice and cool but still did not fix the issue. I eventually got a tow back to the ramp.
I very much appreciate any insight that any one could give me for this very elusive problem.
Thank you guys.
Thank you guys.
