Shift Linkage?
JimS123
A buddy has a Bayliner with a 3.0 Mercruiser. Problems with shifting prompted some adjustment of the shift cable. Adjusted one way and it goes into reverse just fine. The other way forward just fine. But can't have both.
Suggestions???
Bt Doctur
Re: Shift Linkage?
worn/damaged control box
worn/damaged shift cable(s)
worn damaged shift cable components
bent shift shoes
worn shift spool
Re: Shift Linkage?
bent shift shoes
worn shift spool
Ayuh,.... My guess is, yer Bud needs a New lower shift cable,...
That 1 is Worn out...
