lawgod@offshore-tax.com
- Jul 27, 2003
- 2
Greetings, this is my first post.<br /><br />End of last year I hit a rock at full speed. Motor ran for a bit (vibration) but quit and would not start when I slowed down. Put it away for the winter.<br /><br />Got it started this year and took it for a quick spin (2 minutes). Now it will not go into forward or reverse.<br /><br />Reverse has always been a problem since I got the motor used. Originally there was no reverse, but I adjusted the two nuts on the shift lever/rod and it would go into reverse with some 'ticking/clicking'.<br /><br />I can spin the prop and can tell when it is in gear (both forward and reverse) by a cluck, increased resistance as I spin the prop & noise as I spin the prop, but as I turn the prop there is not enough resistance - it is not turning over the engine.<br /><br />Any suggestions, what trouble shooting should I do to try to identify the problem? I don't even know what to look for if I open it up.<br /><br />Thanks
