ok heres one I have a 18 ft 1986 sea sprite 205 hp v6 4.3 alpha 1 <br />when i shift from forward to reverse with the engine off it a smooth process when I start off from the ramp with engine on from netrual to reverse then into forward its fine but later in the day comming back when I'm in forward gear and go into reverse to slow down to make adjustments at the ramp it sticks hard sometimes I have to shut off the motor put it in netual start it back up the go to reverse or pull on the lever to the point I feel I'm going to break the shifter.<br />I have adjusted the cable seems to help but very little then the next trip out it happens again ita real problem at the dock what can i do? Alos I have adjusted the idle to 800 that helped a bit more do I need a new ****er? again when the motor is off its fine thats the key i think. uniflex ****er the plasic guide inside is worn a bit could that be it but why does it shift fine with the motor off here is a pic of the guide its not mine but it looks like this any one have a spare or a ultraflex shift for sale ?http://ebay0.ipixmedia.com/abc/M28/_EBAY_335de034d1768a9be4ed3175f268cba8/i-5.JPG
