I have a 1972 125hp electric push button shift that lately when trolling poppped out of gear and into neutral...shut off the key switch and it goes back into gear. Second problem is when I put direct power on take off the engine slips into neutral and the engine RPM's go up, but yet if I ease the throttle it goes ok. Any Ideas as to what this could be?? I checked the prop hub and it looks fine? This engine has no shear pin, just a rubber inner hub. <br />--------------------------------------------------------------------------------
