Shift Rod Height
Skywatch
I have a 2000 175 hp Johnson, 25" shaft V6, 60 degree motor. The book I have calls for s shift rod height setting that is way too long for this motor ( I run out of rod before getting the stated height). Does anybody have the correct shift rod setting for this engine mod. # J175VXSSS?
Thanks,
Dennis
GA_Boater
Your posts in the Chrysler/Force thread have been deleted. Moved this post to it's own thread. Please look at the Help Tips on top of the page and please do not post in inactive threads. Thanks.
Chris1956
I have the spec for a '98 Johnny 175HPV6 60* motor. The shift rod height for a 25" model is 26 1/4" +/1 1/32"
Skywatch
Thanks Chris. That is the same setting the book I have gives, but it's way too much for this one. My rod is too short. OMG did I just write that?
Chris1956
Well, if your (shift) rod is not up to the correct length, you have a problem. Maybe you have a shorter shaft? There is a spec for a 175EX/NX motor which is 26 1/4 inch. Does that work?
175 FT shaft spec is 21 3/4".
