Hi everyone... well yesterday i changed the impeller on my 1980ish 85hp merc outdrive, and ofcoarse i played if the shift rod, taking out of alignment.. (didn't read the instructions pryer to doing the job) so now the its stuck in forward gear... I have read every single post on this site, and every other web site with no luck... the problem is I can move the shift rod on the lower unit about 3/4 of a turn in either direction, with out shifting anything or feel any resistance at all, once in awhile i'll feel a little bit of a grind in certain spots, but other then that, it doesn't do anything else... do i screw something up real bad?? i've tryied moving the rod slowly whille spin the prop, and nothing changes... please help... thank you in advance John
