I have the manaul, but cant see where or how i am ment to release the shift rod under the power head?? the carbs are off, all i can see is a pin at the top of the rod, should i try to remove this? any help would be much appreciated
thanks heaps ill try that tonight, however there is no bolt nut? to undo? just a 3mm pin at the top of the shift rod and gear arm, it may be a bolt with head sheared off?
