Re: Shift shaft disconnect for lower unit
I had just dropped my L/U a couple days ago, I just left it all in nuetral. I had almost no problem getting it all lined up, just make sure your water tube lines up right, thats the biggest train wreck. I had to stick mine up in the motor and let it hang, line my L/U shaft up in the motor, turned my flywheel just a tad at a time so the crankshaft and driveshaft lined up, lined my water tube up to the water pump housing with my finger, and KAZAM!!! Just slowly tightned all my nuts at a time, everything went well. <br /> Just dont decide to swick gears for any reason in the process.
