shift shaft seal question
G22inSC
Just curious as to what the signs are of a bad shift shaft seal. Trying to learn a little about the Alpha One Gen II and wandered what to look for. I would greatly appreciate any insight. Thanks.
dubs283
Re: shift shaft seal question
milky gear lube, loss of gear lube
only way to know for sure if the shift shaft seal is bad is to pressure test the drive
Soder99
Mine was leaking a couple years ago. I didn't see water intrusion, but it did leak on my driveway and drained a part of the fill reservoir.
If in doubt, replace. It was inexpensive and easy.
fishinrado
Hi , just saw your post! Did you have drive oil coming from the intake weep holes on the port side?
I have NO water in the drive oil ( just drained and inspected) but have a little of the green gear oil leaking from said weep holes and am trying to figure it out! have it apart now to do the impeller and seals which have not come in
Thanks!!!
Soder99
I don't recall exactly where it was coming out. I mostly remember following the drip to the shift shaft seal. Sorry my memory's not better.
