Shift slop, are these parts interchangeable?
nola mike
Merc 170, alpha 1 gen 1. Having a hard time getting into gear, both forward and reverse. I have some slop in the shifter cable, which is apparently now just bad enough that I can't adjust my way out of. Noticed some low hanging fruit where the shift interrupt plate mounts. I have a stud there that is quite a bit smaller than the opening on the plate. Looks like it's missing the spacer and sleeve that go over the stud. The parts diagram shows a "new style" bracket that just uses a bolt with a shoulder (the spacer/sleeve are listed as NLA). Anyone know if these parts are interchangeable? The stud is 10-13743, the spacer/sleeve are 23-37981/23-45600. This vs. This
nola mike
To answer my own question, it appears that they are. Ended up with the bolt, which appears to work. Shifting fine on land, we'll give it a water test this weekend.
Quick shout out for good service:
Called around locally, nobody had either part. Local marina (Rapa Marine in Tappahannock, VA) said "I may have something used, come on by".
He dug around, pulled out a whole shift plate and hardware. Asked what I owed. "Nothing, hope it works". I know where my business is going in the future.
