Shifter conversion
Trickle56
Does anybody know if you can convert the older side shift to the tiller shift style? I have a 1985 25hp was wondering, if it is possible to get the shifter and linkage off the 90's tiller shift and retro fitting it to the older models.
Easy conversion....sell the '85, buy a newer motor
gm280
To answer your question, YES it can. But only if your engine was available in both options. Otherwise everything would have to be custom made, sort a speak. Some OB's were offered in tiller and remote setups. And they have similar parts on each version. But you would still need to locate any part you presently don't have for the conversion. If you are really ingenious, you can convert most any OB engine to either version from the other. But clever ideas will be needed to accomplish that as well as some very unique hand made parts. Whatever you decide to do, just make certain it is well thought out and executed for safety reasons. JMHO
I think you just have to find a motor with the front shift tiller set-up.------Then bolt that up to yours.
