Shifter handle
Caretbay
Good morning all, attaching the cables to my single handle shift throttle control box. The arms are perpendicular to the box which I'm assuming is neutral but the only way the handle will initially attach is if it's in line with the box which obviously is not neutral.After attachment, when I move the handle so that it will be upright for the neutral position this of course moves the arms so they are no longer in the neutral position. Not sure how to get the handle and the arms so they are both in alignment for neutral.
Any idea what motor you have ??-----Nobody here knows what control box you have !
Caretbay
So, I disassembled everything and started over and lo and behold all is good. Thanks All
