Shifter prob? Hard to find nuetral-165merc
tjaizmopars
JUST PURCHASED-1979 Bonanza- 165 I-6 Merc , shifter has knob you pull out for nuetral ,does not seem to be going into N(shifter does not feel looser as it should when in nuetral) - also when I did get it to go into N would grind when going into fwd & rev and sometimes die when put into rev.- SHIFTER ADJUSTMENT OR REPLACE - OR SHIFT CABLE ADJUST/REPLACE- OR SHFT SOLENOID CUT-OUT SWITCH FOR IGNITION ?? PLEASE HELP --THANK YOU - TJ
Re: Shifter prob? Hard to find nuetral-165merc
"SHIFTER ADJUSTMENT OR REPLACE - OR SHIFT CABLE ADJUST/REPLACE- OR SHFT SOLENOID CUT-OUT SWITCH FOR IGNITION ?? "<br /><br />Any, or All of the Above.....<br /><br />Also, you Shouldn't have to push, or pull Any buttons for Neutral.....
tjaizmopars
Thanks , but I was hoping to see what could be checked to determine what exactly problem is-also the button that I pull out on shifter is to disengage outdrive ?<br />All help on this greatly appreciated - TJ NEWBY
