zepplinswt
- Dec 27, 2002
- 9
Mercury Shifter on 2001 Mercury 125 ELPTO. Yesterday at the lake it was idling fine. right around 800 rpms. after running across the lake at WOT then coming into neutral it was idling at 1600 rpms. When shifting into gear at this idle a loud clunk occurs due to the idle to high. The shifter feels different now when using it. Seems like when shifting into forward gear there is a lot of play once shifted into gear and throttling up. Reverse is harder to get into gear it seems. The high idle has happen before and soon after corrected itself...not sure what the cause of this is but I don't think it would be the idle screw, seems to me that the shifter and linkage may be to far advanced when in neutral...is this even possible? any suggestions would be great. thanks.
