SS MAYFLOAT
- May 17, 2001
- 6,372
Toward the end of last years season, my cables were getting harder to move. Having a dual helm, I have twice the number of cables. It will get pretty pricey to replace. Plus the routing of them would be a major pain to pull new ones through.<br /><br />I have some tanks that has a bottom pickup tube, then another fitting that is for air. (They were designed as a pressurized vessel). <br /><br />I was planning on using a Kerosene/oil mixture to flush and lube the cables buy hooking a hose over the cable end to the outside jacket. Then the other end of the hose hooked to my pressure tank. Of course apply maybe just 5 psi air pressure to start out with, then work the cable back and forth from the other end till residue of old contaminates comes out.<br /><br />What lube should I use to flush out my cleaning mixture once the cable move nice and free? Any suggestions?<br /><br />Thanks from the SS.....
