I have a 2000 Volvo DP-SM drive, if I run the boat a long time and take it out of gear I have difficulty getting it back into forward. Reverse works fine, but I need to really give it throttle to get it to grab forward- its like it just isnt moving the shift cable.
When this happens I have been putting it into reverse and then neutral, that sometimes will fix the issue. Short trips around the harbor and I have no issue.
I assume this is a cable issue but I did adjust it in May and all was well.
Do cables stretch over time or are they considered a wear item? Is it my control box? This is a single lever unit- perhaps when the throttle is advanced its throwing the shift cable throw out?
Thanks for any input.
