BenPainter
- Feb 14, 2013
- 17
I have a 1997 33' Stratos center console with twin Evinrude 225 two strokes. They are the original engines, and with the exception of the amount of smoke they produce have been running fairly well for 3 years. This past Sunday, I took the boat to a local lake to hang out with some friends. Both engines ran just fine on the way out. After sitting for a couple of hours, we were pulling anchor to head to pick up some more friends. I started both engines but noticed something feeling wrong with the starboard engine. After I got it started and tried to put it in forward, it felt like it was not engaging the prop and was very "loose" as in easy to move. This is not normal for this boat as usually the shifters are fairly sticky, and usually have to be muscled a bit to shift. (it felt like when you disengage the shifter so you can rev the engine with it still in neutral). After messing with the shifter and the disengage button, thinking it might have gotten stuck and it would not shift into gear... I realized that the boat was shifting into reverse (very smoothly) whenever I shifted the shifter forward to put it into forward gear. Oddly enough I realized that if I pulled the shifter back, it also went into reverse. So, it will shift into neutral, but will go into reverse if I push the throttle foreward and will also go into reverse if I pull the throttle backwards. I pulled the engine cover and visually saw that when the shifter was in neutral, the lever on the side of the engine was in the middle position. When the shifter was pushed forward, they lever moved one direction, and when the shifter was pulled back, the lever moved in the opposite direction.
I have searched archives and cant find much information with this problem. Any ideas of what this issue might be? I assume the next step would be to pull the lower unit and see how its is shifting by hand, but the boat is in the water and the boat would have to be pulled to pull the lower unit. It would be nice to avoid the cost of that since the bottom has been recently pulled and painted.
Thanks for any information you might have.
Ben
Ben
