Hi I just bought a new used boat, Its a reninell 181brxl with the 4.2liter HO motor its a 1993. The motor ran great on the flush attachement and ran great for first hour of use, super quick and fast loaded with 7 people so it seems very strong. The first problem I noticed was when trying to start the boat the straight up position where the throttle control is locked in the straight up positon will not allow the boat to start but u have to actually go slightly back maybe 15? to find the start postion is this normal or does linkage need adjustment and if so how to adjust it? Also normally clunks into gear and I think this may be caused by idle being two high, boat says 1200rpm but not sure to believe this or not as on the lower end the rpm gauge bounces all over but at wide open its 5k rpm. The throttle control isn't sticking at all very smooth. Also when pulling straight back to the locked center position the boat is still in gear and were still moving untill I pull it back and find that slight back postion then I can move it back to the locked postion and it stays in neutral.
The next problem is after running it wide open and then shutting it right down it was diesling. After doing this many many times we broke down in the lake got towed back. Took all the plugs out and all cylinders had water in them it wouldn't turn over with all the water in there. We turned it over with the plugs out and blew out all the water sprayed some wd40 in the cylinders and retested it and it ran great beside the shift issue for over an hour but we let it idle for 60 seconds or so each time before turning it off. I have heard diesling can cause this water issue there is not water in oil at all. I was running just regualr gas and have also read that running higher octane can help this problem out? I suspect the diesling is caused by the shift linkage and throttle control not being set up right but am not sure how to adjust this or if there is any other better explanations?
Thanks Alan
Thanks Alan
