nola mike
- Apr 22, 2009
- 5,625
So i have a slight issue with the shifting on my new-to-me mercruiser i/o, which i thought was just a simple adjustment (maybe still is, i just can't figure it out). when i'm in forward, i need to move the shift lever slightly into the reverse position to disengage. all gears shift smoothly. i've read through the stern drive manual, and haven't had much luck. also, i haven't been able to find a "how-to" on this forum, though i'm sure i'm just missing it.
perhaps someone can fill me in on my knowledge of the shifting mechanism--maybe the adjustments will make more sense to me.
as i understand it, when i shift into gear, the shift cut out engages, along with movement of the shifter cable. as the handle is moved, it appears that there's a "shock absorber", whose job is to move the shift interrupt switch back to the neutral position.
as i said, i tried the book adjustment. here are the problems i'm running into:
there is no mention of adjusting the actual shift cable, though there is an adjustment barrel on it. how is this done? i would think that this would be the adjustment that i would want to focus on, but have been having a hard time getting it right.
the remote shift cable's length seems mainly to determine the relationship between throttle opening and shift cable movement; ie, when the cable is shorter, the throttle tends to open before the clutch engages.
if i manually activate the shift interrupt switch, i'm assuming the motor should stall--mine doesn't seem to do anything, though as i said, it shifts smoothly out of gear.
i'm wondering if i just have a worn cable/need lubrication somewhere/something else instead of a simple adjustment. oh, everything shifts fine when activating the cable by hand.
