shifting problem
splatter
I just installed a new SE106 out drive onto my 83 sting ray .When the boat isn't running it shifts fine . When the boat is running it shifts into forward fine but is almost impossible to get it out of forward and into neutral . Once in neutral it shifts to forward or reverse fine .
solar7647
Re: shifting problem
Did u install a new shift cable from the drive or did you use the old one
thumpar
The shift interrupt is what helps the drive shift out of gear. The clutch dogs lock together and the little loss of spark lets them unlock. It could be the cable is out of adjustment, needs replacing or a problem with the switch. On land or not running you would not notice it.
splatter
Turns out the previous owner had disconnected the interrupter switch . I reconnected it and adjusted the lower cable now it works great. thanks again
