I have a 1999 25HP Johnson that I just serviced the water pump on. Everything went well on the pump install. After installing the lower unit, I have a small shifting problem. I can shift from forward to neutral fine, but not as well from reverse to neutral. After shifting from reverse to neutral, the prop still spins. If I just tap the shift handle a little to forward it goes to neutral.
I have the shift rod linkage as tight as it will go, but It seems I still need a little more pull and it would be perfect. It worked fine before, so I'm not sure why it's like this. Is there any other adjustment I can make?
