shifting problems with 25hp merc
MrBrownTrout
I took my 1995 mercury 25hp with tiller handle out fishing today, first off it would not turn over because our temps have been cold, well I got it to turn over and start but now it won't go into neutral or into reverse, when I turn the handle to go into reverse it just continues forward. Anyone know what might be wrong?????
bcfryer
Re: shifting problems with 25hp merc
the shaft in the tiller arm is stripped out at the cable pulley. Just had mine replaced under warrenty
sear99
I have a similar prob. but mines stuck in reverse, and the cable moves when I turn the handle.
ehenry
Have you replaced the impeller recently or had the lower unit off for any reason? If so there is a washer that slides down on the shift shaft that may not been reinstalled. The same thing happened to my 25 hp merc and thats what it was.
