I removed the lower unit of my 1998 Johnson 25 HP to replace the impeller. When I put the lower until back on and connected the shift shaft I am not sure things are correct. With the shifter in forward, should I be able to move the prop? What about in neutral and reverse. I want to make sure everything is ok before I try to start it.
Thanks,
Neil
Thanks,
Neil
