anthonyvittore
- Jun 28, 2008
- 10
I just replaced the impeller, with the help of you guys on this post. I installed the lower gear today and now it will not go into reverse. It was hard to get it out of forward. When installing the lower gear I had to spin the propeller to get the splines to line up. Do any of you know what might cause this to happen? Would the impeller but in the wrong way cause this? Thanks for your continued help!
It's a Mercruiser 140 HP 181 Inline 4. S/N 5551275.
The drive shaft has a push pin on the top......
