1994 3cyc 90HP mariner<br /><br />Well I discovered why my engine only had reverse gear, after disassembling the lower end, I noticed that the three balls that are between the cam follower and the prop clutch are missing. Last season my brother replaced the drive shaft, and I think he mistakenly lost those three balls, not knowing, he put it back together anyway.<br /><br />Does anyone know where I can order these? I assume a copper BB is not the same size, nor the way2go. Any help would be appreciated. Below is a PDF of the lower end of my motor to assist with this post.<br /><br /> http://66.192.131.203/manuals/1416/pdf/14167e224.pdf
