Re: Shimming tool A B C. Not X Y Z
Interesting. Is that a factory tool or aftermarket? It sounds aftermarket. And it sounds like the tool is not stamped correctly.
Serial numbers 0K999999 and below use tool 91-60526, and it should be marked XYZ. But serial numbers 0L100009 on up use tool 91-854377, which is stamped ABC.
You either have a Gen 1 tool with Gen 2 stampings. Or a Gen 2 tool with a Gen 1 part number on it. Does that make sense?
