Shop manual, points for early Merc 500
shelbygt
I'm looking for a Mercury shop manual for 61-64 Merc 500 and points also.
GA_Boater
Re: Shop manual, points for early Merc 500
Set of points - Get your wallet out. No longer available, so the sellers have you over a barrel.
What is your serial number?
GA_Boater
40-50 bucks for points is bad. $10-20 is acceptable. Like I said, NLA has you over a barrel.
shelbygt
I have two. 1961 s/n 1427647 and 1963 s/n 1555410.
shelbygt
I understand folks are cleaning them. I've worked on many cars, few outboards. Guess it was always my understanding there was some kind of coating and if you took it off the points wouldn't last long. That's what my dad told me anyway. Is it different with outboards? :confused:
How do folks clean them?:confused:
shelbygt
Points are not too bad. Scour ebay and they pop up in the $50 range.
393-1504A is the P/N.. Quick search. These will probably end up in the $40 range most likely. No watchers right now. Mercury A 393 1504A5 6 Cyl Breaker Point Cam Wick Assembly Vintage | eBay
Or this one Quicksilver Mercury Breaker Assembly 393 1504A Free Priority Shipping | eBay
Item description says 6 cylinder, are points the same for the early 4 cylinders? I haven't had the distributor out yet. Is it keyed or do I need to be careful and mark things?
achris
More fish than mountain goat
Here's your manual... Mercury Outboard Marine Motor Factory Service Manual 1965 and Prior C 90 25500 | eBay
Avoid the one listed above, it a cylmer on CD... :facepalm: I once bought one thinking it was a genuine one... Returned it and got my money back...
Original part # for the points in your 50 - 393-1504A6, original part # for points in the 6 cylinders, 393-1504A5. Both parts supersede to 393-1504A11. Based on that... They will most likely work....
Chris.....
shelbygt
Chris.....
Would 393-1504a 10 work?
shelbygt
Is there a part number for the condensor?
matt167
Yea, but Old Mercs wants $120 for a set of points. I'd rather shop around for the $30-40 deal
matt167
Chris.....
Actually the manual for '40-'65 is genuine Mercury Part # C-90-25500. and comes in a PDF on a CD. I took a chance on it because I found it was supposed to be OEM from Johns Old Mercury site, and it is. Saved me a lot of $$..
matt167
They superseed to A11, which is the last part number the old 4/6cyls used for the 'pre '67 motors.. Condensor crosses to Sierra 18-5169 and is available new. The Mercury condensor is still pretty easy to get ( may still be available ) 394-1130A1
shelbygt
Thanks!
shelbygt
You guys have been great. Found shop manual, parts manual, points and condensor. Time to go to work....
