Shore Power
slosacco
I had a 1985 Century Meridien given to me and I cant get the shore power to work all the lights on the boat, it justs works the outlets on the boat. I do need new batteries and a number of other things to..... Is there a switch somewhere because I cant find it.
wire2
Re: Shore Power
Are the lights 115v ac or 12v dc?
If ac, there may be a breaker tripped.
If dc, I expect you have a 115v-12v converter somewhere that's not turned on. It will be close to your shore power panel.
slosacco
Re: Shore Power
The lights are 12V, when I connect the batteries everything works. My breaker panel has five breakers, 1-main 2-outlets 3-refrig 4-water heater 5-range. Does the dc power work off the battery and when its plugged in it charges the batteries? Thats the only thing I can think of.
I'm new in the boating world....... :)
wire2
Re: Shore Power
There would normally be a 115-12v converter in there to operate the lights, water pump, exhaust fan, etc. and keep the batteries charged.
Same as in a motorhome or travel trailer.
There is a chance you don't have one, if the dealer offered it as an extra cost option, or someone may have removed it.
slosacco
Re: Shore Power
Thanks for taking the time to help. I will check it out tomorrow and see what it has.
