Short term storage /parking transom question
lifeisfun
I take my inflatable out every week or so and I wonder what is the best for the transom ...
Motor is little over 50KG (4 stroke suzuki 9.9) and I like to know if it's better to leave the motor hang down ( and perhaps shim it to support it from the concrete garage floor or should I leave it slightly tilted with transom saver in place ?
Thanks
tashasdaddy
Re: Short term storage /parking transom question
transom saver. but in winter months let the engine down to make sure all water has drain out. don't need a cracked gear case from water freezing. then you can put it back up.
lifeisfun
Thanks !
Finally easiest way is the proper way :)
In winter time I store my toys in heated garage :)
