Short vs. Long tailshaft on 14 ft. jon boat.
Bearcamp
I have a 14 ft. jon boat that takes a short shaft motor. My question is, if I make an adapter for the long shaft motor to mount on the boat, will there be any harm in doing this? What are the pros and cons? I figured as long as I made my mount to make up the difference, I don't think I'll have a problem. BUT, that's why I'm asking the people that know best. Also is there an adapter mounting bracket like I'm talking about available to purchase?
steelespike
Re: Short vs. Long tailshaft on 14 ft. jon boat.
Sure it is possible to build up the transom but<br />your talking 5 inches at least, so you will need to be sure you build it strong enough to be a true transom not just a filler block.<br /> Not an expert on jack plates but you may be able to use one .<br /> I think unless the long shaft is a special<br />motor I would trade for a short shaft.
