shortening shaft ?
pine island fred
Got a question, one of many to follow. Rigging/ weight/balance on a friends boat is way off. First thing I noticed once out of the water is that the 25 in. shaft on this 2 stroke nissan is entirely to long. Is it possible to remove the shaft extension spacer? Is there a drive shaft and shift control extension inside the leg that can be removed or is it all one special piece? How about the tube from the water pump? What a mess! thanks FRED
TOHATSU GURU
Re: shortening shaft ?
You will need a new driveshaft, watertube and shift rod and you will have to pull the powerhead to get to the watertube.
pine island fred
Thankyou for the response! Was afraid that would be the answer. Had posted the ? on the general discussion as I figured all O/Bs would handle the extension in the same manner. Time to consider some serious modifications. Measured the distance from the C/L of the prop shaft to where the leg comes out of the water. 28 ins. with another 5 and 1/2 ins. dry to the top of the mounting clamp. 30 ft. houseboat ( LIL HOBO) needs 35 1/2 ins. of water. Stern of the pontoons are 2 ins. out of the water.
Will TOHATUS and NISSAN legs interchange ? regards FRED
Marv
Easier to raise the outboard up with a bracket or hydraulic lift.
