Should I change from rollers to bunks? 18' tin
ctswf
I don't particularly like bunk trailers, but after sighting my 18' tin starcraft it looks like the tiniest arc might be forming around the rollers on the starboard side. I did have a lot of snow weight on it this year.
It's not a problem yet and might even be temp flex due to the boat sitting a little crooked from my trip last week.
Do u all use bunks on your tin boats?
dozerII
Re: Should I change from rollers to bunks? 18' tin
Hey ct, after what I experienced today with the bunk set up on my Ezloader I will never go back to rollers, what dream to load and unload, and it will never dent my hull. Just my honest opinion thou.
ctswf
Why is it a dream to load/unload? I had a bunk trailer years ago with my fiberglass and I remember thinking rollers where a dream once I switched to them
dozerII
I backed it into the water till the rear of the hull was in about 6 inches, unhooked the bow strap gave it a push and off it went. When it came time to load, I backed the trailer down till it was a foot from the water pulled the boat over stood at the end of the trailer clipped the winch strap on then tightened it up so the bow was between the lower bunks, then went up to the winch and cranked the boat on while the Admiral let the trailer slowly roll back into the water, easiest load ever.
ctswf
We'll that does sound easy :)
MikDee
Banned
Try doing that alone! I cursed the roller trailer my boat came with. I couldn't release the boat, then get into it, and back off the bunks like usual. :mad: I always needed someone to release the boat once I was in it. The same thing when loading, no way could I get to the front of the boat to latch it on. :rolleyes:
dozerII
Another reason I don't like roller trailers!!
SigSaurP229
I switched my 18 from bunks to rollers I will NEVER own another roller
Watermann
I have both, not sure either one is a problem worth converting over. If I had a roller trailer with a bunch of rollers that needed replaced then I would covert to bunk because of the cost and pain in the ... of roller replacement.
cj8mule
I unload and load by myself most of the time and a bunk trailer with side guide on boards is the best for me. The only time I would want a roller trailer is for shallow boat ramps.
duke33
I just learned something. Another reason to like this place.
ctswf
thanks everyone, i will stick with what ive got for now. the season has started afterall!
jasoutside
Bunks all the way for me. I launch/load by myself all the time, or worse, with kiddos to tend to also. That boat stays right where I want it till I want it off.
I think it really depends on your whole launch/load methods and what you are comfortable with. No way I'd run rollers but to be fair I know a lot of guys love them.
Rock on:rockon:
STARCRAFT16SS
Add me to the list that like rollers....but to be fair...I've never had bunks..except on the sides to guide the boat to the
correct location on the trailer.......pictures of trailer are from a few years ago...I have done some changes to the boat since then......
kevingr
Bunks, with a drop axle. The boat rides low and I don't need a lot of water at a ramp. I hated the roller trailer that my Holiday was on, sat higher than the fenders and was a pain to get off and on.
astor
2018's Starmada Splash Of The Year.
No to rollers here. I will be removing mine and replacing with bunks and keel rollers. Anyone want my rollers?
here are the issues I have with them:
1. insufficient support to aluminum boat hull- resulting in dents and even cracks
2. expensive to replace rollers
3. black rubber rollers mark the hull
64osby
The 21' Mariner has been on a Shorelin'r 32 roller since 1973 with no hull issues.
I like the rollers for my uses. Haven't had to use a really steep launch.
If I were a full time river boater I might look at bunks. My .05. For those North of the Border
InMotion
I am pro bunk! Yup... they work great. Never had any issues and they support the hull well. My .2543 Cdn Cents!!!!
J.
mv6767
I was taught that rollers are for fiberglass hulls and bunks for aluminum.
Grandad
I had rollers with my fiberglass hull and now have bunks with my aluminum hull. Both worked well. I've got a couple of pieces of 3/8" thick slippery UHMW plastic that I'm gonna try instead of carpet on my bunks to try to get the better support of bunks plus the ease of loading of rollers. When I get a round tuit. - Grandad
