64osby
- Jul 28, 2009
- 6,826
I have re-trailered my boat and am looking for advice from you experts out there if you think this is a good option or should I go back to my old trailer.
The reason for the switch is the EZ-Loader has a wider axle and it allows the boat to sit lower. With my Gator I have to back up till I hear the exhaust is in the water then I can offload the boat.
Old trailer is a Gator probably came with the boat 1964ish.
Newer trailer is a 1980?s EZ-Loader 12 roller. I have contacted EZ-loader and will be sending them some information that will allow them to determine the exact trailer I have and its capacity, based on rough information from them the trailer has either a 2500# or 2700# GVWR rating, trailer should be about 500#. The VIN and capacity plate are not readable.
The boat is a 1964 Crosby ? shipped weight was 505#
I have a 1967 Merc 500 estimate 300#
Too much junk and 8 gallons of fuel 350#
Trailer estimate 500#
The questions I have are
1) Should I use a roller trailer on a 45 year old fiberglass boat? I am wondering if there will be too much stress on the boat at the roller locations.
If question 1 is yes, then
2) What is the relationship of keel rollers to the support rollers, should they be carrying equal weight or should one carry more weight than the other?
3) Rear rollers are about 4? in front of the transom should I get them back to 2? or less?
4) Should I add an additional keel roller for the front portion of the keel?
Items I need to fix and adjust if it is the right trailer are;
1) Raise the winch so the eye is below the roller.
2) Add new chain / turn buckle from eye to tongue
3) Maybe add a keel roller at the transom
4) Rewire lights
5) Repaint
Thanks in advance for any input
62iia
4) Rewire lights
5) Repaint
62iia
