Should I hear carbs run like this?
Bassman42
I have a 97 evinrude 115. E115eleua, it has a remanufactured powerhead, 40-50 hours on it now. I noticed that the more broken in I have it the louder I've been hearing the carbs.
https://youtu.be/YpdsYxDXEX8
Watch this video, towards the end I take the upper cowling off. I'm assuming it's okay but I'd rather be safe then sorry, it's starting to run lean(with no adjustments to the carbs since the remanufactured block was put on,) and I've evidently been putting 2 fl oz of oil less then it calls for, pint of oil per 6 gallons of gas. I don't trust the vro. Long story how I learned that I put less in it, it bogs down only if I gun it very quickly, which is needed if you try to fling your wife good off an inner tube!! other then that it runs strong as it ever has.
jakedaawg
Its hard to hear there. Any chance you have a big barrell to run it in?
Bassman42
I can later. You couldn't hear them when I took the upper cowling off? It's right at the end of the video
Bassman42
It's tight, and it hasno obstructions in it, BUT, I've always had gas from all 4 carb throats seeping into the airbox, and then rolls to the bottom part of the cowling, and the shop told me it's fine and normal..
Bassman42
But they also told me, after they replaced the fuel pump and everything else, that the company who did the reman powerhead(obr) said they had put a starboard piston in a port spot, and vise versa, when it had all the symptoms of a new defective fuel pump
F_R
Face it, carburetors and the reed valves ahead of it are very noisy. That's why they put a silencer on it. The motor cover is a second silencer.
Faztbullet
They will run and idle just no mid and top end with pistons swapped. Did OBR repair it or that shoddy shop you used fix it. If they swapped it without OBR's ok you/they voided the warranty.
Bassman42
It wouldn't run at all lol, obr sent another powerhead. They said the walls were scored. The only way that motor ran at that time was if you constantly primed the bulb. Before they "discovered" that issue they told me they jusy started throwing parts at it, and right at the end it ran great again with a new powerpack. I drive an hour and a half to pick it up(prices were much cheaper then shop 15
Minutes from here, and when I got there they said it started messing up again
Bassman42
My business is finished unless it overheats for detonated from the work they did I found a few things that were not in the proper setting, (according to the manufactured service manual I just bought) btw best $50 I ever spent!!
