Should I or shouldn't I disconnect?
jstaz
My 1994 Tohatsu 60 HP has an oil tank and it does the whole auto injection thing. However, I have read and heard and been told that many fellas don't trust that system because if it fails you burn up the motor. They state to mix your gas.
Should I do this for insurance?
Do I need to disconnect the oil injector system or can I mix and keep that system operational?
Whether I keep it hooked up or only mix the gas... What ratio should I mix? 50:1? 25:1?
I am new at all this so any help and comments would be helpful. Thanks in advance y'all.
pvanv
Re: Should I or shouldn't I disconnect?
That oiling system is extremely reliable. Nobody premixes on these motors. If you did decide to do a premix, 50:1 is OK. If you disconnect the system, you would also need to disconnect the oil level sensor, or the empty tank reading would give you a low oil alarm all the time.
jstaz
Thank you for the input and the help. I think I will leave things hooked up and not bother with mixing at this point.
