Should I Replace These....
BigDaddy5517
Hi, While I have the drive off the boat should I replace these two gears or are they good for awhile longer.....
Also can someone help me identify these plugs... I believe 1-is the dipstick 2-is the drain but I don't know what 3-6 are.... Thanks all....
Bt Doctur
Re: Should I Replace These....
Replace the ball gears
1 dipstick
2 gear oil drain and fill
3 allows access to a grease fitting
4 vent, oil level
5 drain and fill
6 ??????
BigDaddy5517
Ok thanks for the reply.... I suppose it would be good to change the oil in the intermediate housing too then... Is that the same oil as the drive would use do you know....
The only ball gear kit I found is for years 1973-1986 on iboats store... Mines a 1969 OMC... are these the same ball gears does anyone know....
