I have a new to me H190 SS with a 4.3 MPI and an Alpha One Outdrive.
I've been doing research on how to properly tow and load it as it's quite a bit larger than my old 16' Sylvan. One of the things that they mention is that you should use some sort of 'transome saver' device that supports the outdrive by using a rod between the outdrive and the back of the trailer? I've seen some people use this but many do not.
Should I be using it? The 112 SPL on the Sylvan had a little 'kick stand' for the engine but the weight was still on the transom and I haven't had issues with that in 26 years. But it's an aluminum boat. I have little experience with Fiberglass boats with stern drives.
