Should I use Polyurethane foam when I replace floor?
aff
Is it worth putting in Polyurethane instead of styrofoam when I replace my floor in my 14 foot runabout. If it is can anyone help me find some?<br />aff
Hooty
Re: Should I use Polyurethane foam when I replace floor?
Stick with the styrofoam aff, that's by far the easiest and best way to go.<br /><br />c/6<br /><br />Hooty
Spidybot
It's different solutions.<br /><br />If you want it to bond with the hull, floor and other parts to build a selfsupporting structure that is strong, you should use something like the recommended foam. You pour it in and it expands into all corners and openings. Can be cut after expanding. Impossible (or almost) to remove later on so you must cover areas that is not supposed to be treated.<br /><br />If you want to fill rather square room you could cut blocks of styro. Easy to remove if needed.<br /><br />Before actually doing the expanding job you might wanna get a sample and experiment with filling various objects.
aff
Thanks for everyones help.<br />aff
