Should my motor beep before starting??
Hi guys,
I have an 87 Edson 175 w/a 87 150XR2,it doesn't beep before
starting??Should it for that year?I remember a freind of mine had
a 135 and a 115 they would beep!I dont know there years.
Kev144
Re: Should my motor beep before starting??
i have an 89 150 and when you turn the key to run, it makes a beeping noise, once the beep goes away, i then go to start it. (FYI beeping is not an alarm or anything.)
j_martin
There should be a short series of beeps if it has a VRO on it. The beeps indicate that a power on self test is running on the Oil Alert module.
Beeps missing indicate a bad alarm circuit, or the module is dead. (or not getting 12 v power)
hope it helps
John
