crappiecat
- Jun 2, 2010
- 8
2003 Yamaha 75 4 stroke has ran well in past years. Let it sit 30 days with no fuel stabilizer and now hard to start cold. It will start and idle but at a VERY low rpm. Mid range to top end back to idle is good and will continue to idle normal. Air intake is not blocked. Stock fuel filter clean, no water. Fuel tank vents function. Couple questions.
Is Prime Start aka the enrichers?
Does the Prime Start operate automatically or by manual push in of ignition key?
Can I remove and clean the enrichers?
Another strange event I've noticed recently, when I stand on the port side (17' v bottom bass boat) while motor is idling it starts to run rough and slower until it dies. If I walk back to driver side all is normal. List to port will kill motor after a few seconds. Carburetors are on the port side of Yamaha, interestingly enough. I've asked dealer about this, no clue.
Great info on this site, keep up the good work.
