Re: Should you or shouldn't you run outboard dry.
This is an interesting subject, and I think that when you turn the motor off, the last induction/exhaust sequence will have some mixture left in the cylinder, whether you run it dry or not. I always run it out of fuel to avoid residue being left in the carbs, but I also start and idle the motor every couple of weeks (run it out each time) to keep it lubricated. As it's cold an wet here at the moment, the periodic running of the motor has a bit of oil dripping from the exhaust after a few days, so I know that it's getting lubricated.
