Rod Holder
- Jan 17, 2002
- 98
Hi all,<br />A few days ago I posted a message regarding the cooling system on my 1973 65HP Evinrude. I got a few good replies (Thanx guys).By the way, this motor is new to me.........<br /><br />Where I'm at now is that there is a steady stream of water coming from the small V shaped drain notch at the FWD portion of housing right where it mates w/ the LWR unit when the engine is running. I had just replaced the pump. The following are things that I checked and/or noticed. <br /><br />Water is circulating thru entire system, coming out both the exhaust reliefs and the outlets below cav. plate.<br /><br />I measured how far the tube should fit into the pump housing (that has a new grommet) when assembled and it should be ok.<br /><br />I pulled LWR end and hooked a hose to the end of tube (that attach to pump) and ran water at low pressure w/ the thermostat removed and cover on. Once the system is full, water starts gushing up near where the the tube comes out. I think it"s coming from a 1/2" or so hole up there. Hard to see while getting splashed w/ water and using a flashlight.<br /><br />Basically, the housing is filling up w/ water at a pretty good rate and I'm left scratching my head.<br /><br />Any ya'all seen this before ??????????
