Long time reader, first post. 2006 Sea Ray 185 Sport, 4.3l Mercruiser, Alpha one gen 2.
So I did something really stupid, put the muffs on to flush the saltwater after having the boat out. Turned water on, started her up. I was tinkering with the wiring behind the dash, had the alarm unplugged to get it out of the way while it was running. After about 4 or 5 minutes I turned around and thought "Man, that's a lot of exhaust smoke behind me." Got down and noticed the cutoff valve on the end of the hose was OFF. Immediately turned it on, climbed back in and flipped dash up, temp gauge was about 205. Left boat running ( probably a mistake ) and waited until temp came back down to normal, about 170. Water was coming out the back like usual. Shut it down, spent about 15 minutes cussing myself and then set about going to the parts store to get an impeller rebuild kit, planning on returning for flapper and hoses if I need them and wondering how much I could get for a 13 year old dinged up boat with a burned out motor.
Last weekend I pulled the outdrive and split it, opened up pump housing expecting to see melted rubber. What I found was an impeller that looks about the same as it did when I installed it in January. (No luck posting photo.) Slight bluing on housing but that's it. Replaced it anyway, checking other things next.
My questuons are, how is it possible that the impeller didn't destroy itself running that long dry? And what other issues should i expect? Engine didn't cut off or sound different, and ran fine on muffs with new pump.Any opinions are much appreciated.
