64osby
- Jul 28, 2009
- 6,826
There are many creative people among the ranks here at iboats. I thought would be nice to start a thread that would allow some of the members to show off their backyard creations, inventions or re-engineering non-boating efforts.
Fall here in SW Michigan has always brought the challenge of leaf pickup at our house. We have about an acre that we try to keep mowed and clean. We have lots of trees and seemingly millions of leaves.
Years ago I used to burn the leaves, fill the drive way in the front yard, 250? long 8? wide about 6? high and light it up, this was done about 4 times a year. In the recent past I have mowed and blown leaves to the tree line of the yard, but the piles would build up and create a high ledge. It has always been a time consuming task and a real PITA.
This year I am trying some thing different. I had an old work wagon, 5 sheets of 2?x5? plywood, some screen material, and some hinges lying around. I built a leaf collection bin. Large vents on the top covered with screen.
I went to one of the big box stores and found a 4" -6" rubber plumbing boot that fit the outlet of my Toro leaf blower, picked up 3 sections of 4? x 10? flexible tubing and a couple of eye hooks. Cost about $30 bucks.
I cut a couple of plywood left over?s to fit the inlet to the blower. In the inlet and the wagon I cut a round hole with notches the let the hose slide in and lock in place.
Here is the set up that I ended up with.
The pictures show our fenced in area where the dog hangs out. I mow the leaves in to strips or runs and then vacuum them up into the wagon. The wagon is hauled to the leave dump area and emptied.
The fenced back yard, about 40?x60?, took just over an hour. To rake the edges, mow and take 2 loads on a slow trip over 400 feet away.
I?m pretty happy with the result. I feel like once the leaves are mowed and hauled away they are not coming back in the yard and clean up seems to go fast. I will still have to do the yard 3 or 4 times.
It has a couple of minor glitches, it clogs up every now and then, it doesn?t like twigs and it can suck up too much sometimes. The hoses will pop out every when twisted, and the wagon needs a wider wheel base, it likes to tip over every now and then.
I can tell when it gets a clog or the wagon is full when the hum or whistle it creates stops. Then I check for a full wagon or a clog.
So there my creation for leaf pick up.
If you have something that you?ve created or improved why not share it with your fellow iboaters.
